These engines are used in various configurations for all sorts of applications... marine, industrial, gensets and others.
They are set up differently for each, with some similarities, but are basically the same motor.
You can run them "wide open" for long periods so long as you keep the limitations in mind.
If you expect to run them at 3600 RPM all day then best of luck in my opinion...
But... I don't think you would have any problem (assuming the engine is well maintained and in decent shape) running 3000 RPM for extended periods. Your limitations are the obvious ones like EGT's, oil levels/changes, filters, etc.
I have heard, heard mind you, that when you get into the 3300 and up range, you should be looking at valve spring changes or you'll "float".
As for the governor adjustment I'll attach a link that has pics I've posted on a couple related items.
If you look at the AFC housing, just below it and slightly to the rear you'll see a tamper cap. (assuming it's still there) Under that cap is the "high idle adjustment"
Its a long screw just like the idle screw, except this one has 2 locknuts on it (10mm I think)
Mark the screw first, then loosen the nuts. Backing the screw OUT of the bracket will increase the high end RPM.
You'll need to have someone in the truck work the gas peddle. Watch the throttle open and be sure that the throttle stop plate makes contact with the screw end... just like the other end of the plate should touch the idle screw at rest.
Assuming it's untouched, you should be able to back out about 1 1/2 turns as a start. Test drive then go from there.
You must make sure the breakover spring is properly adjusted afterward as well... . here's the link to the post with pics...
http://216.235.147.117/forums/showthread.php?threadid=21040
Bob.
