RPMs with different rear axles and trans
inexpensive power upgrade for '04?
spring wrap ???
Thought I would post this info for those interested in deciding which rear axle ratios to go with, if others chime in with their observations for their particular configurations that would be great. I have the 4. 10 and 48RE. Cruising at 70mph, the RPMs sit right at 2150. Stock BFGoodrich on/off road tires.
Trying to remember what my '03 with 6 speed and 3. 73 ran for RPMs at that speed but I don't think it was much less.
Originally posted by XJSuperman
Just to add... with my 48RE 3. 73's with the 315's... sits at 1800 RPM's at 70.
That's corrected 70mph, right? You had your speedo adjusted, I presume? So does that mean you're only at ~1450 at 55mph? Hmmm... maybe I do need those 4. 10's...
Yes I had my speedo corrected. In OD I am at what was said (1450 I think) at 55. BUT I don;t run OD unless I'm doing better than 60 MPH. Works great for me.
