RS9000 settings
Northwest Custom
BD exhaust brake; same e-brake for both manual and slushbox?
4 brand new ones going on in the morning. So for you RS9000 owners, wheres a good place to start with the settings. Front and Rear. How about empty and towing 7000# with the canopy packed.
1997 2500 4x4, CC, Auto, 3. 54 LSD, 66K, Everything inc Leather, K&N, 4" BD cat-back, otherwise stock, Isspro Gauges(3), 285/75/16 on Alcola's, RS9000's, Canopy, BedLiner, and tons more.
I started with "3" on front loaded and unloaded. "2" on rear unloaded and probably "3" or"4" with the load you indicated. Works well for me.
I run "3" on the fronts (Front axle weight @ 4,300 lbs) and "2" on the rears (rear axle weight @ 3,300 lbs). Have a 600 lb camper shell on the truck. Rides nice.
Frank Dziurda - K7SFN
Carson City, Nevada
'99. 5 2500 4X4 6-Speed Quad Cab LWB 3. 54 LSD
3-4 on front, 0-1 on rears.
'94 3500 4x4, 209,000 miles, Never had a cat, Auto w/shift kit (thanks Dave G), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro Gauges & Amsoil Air, Oil & Bypass Filters & Lubes, AWOL intake boot.
Punchlist: X-Mount Mirrors, 14 cm Turbo Housing & 215 Injectors.
NRA member.
Blue Ribbon Coalition member.
"Warrantee? We don't need no stinking warrantee!"
3 on front, 1 M/T, 5 w/5th rear
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T, Reese 15k 5th slider, EASLEY BULL BAR, WESTIN NERFS, TA's, 9000's,Cummins 505 ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", DTT VB,TC,TC SAVER and AUX COOLER, PAC BRAKE, MAG HYTECH TP& DC, AFE filter onboard. Taylor Wing and Gear Vendors on order
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
2 in the front and rear empty (65 psi in the front tires, 50 psi in the rear). 3 in the front and 5 in the rear with the camper loaded (65 psi in the front and 80 psi in the rear).
1999 Quad cab 2500, SB, SLT, 4X4, 5-speed, 3. 54, tow and camper package, Lance 820 camper, Lance cabover stabilizers, Rancho 9000s, Airlift airbags
