Hey guys, here's an off the wall question. I am looking for a part number and/or source on the rubber seal attached to the door itself. One of the seals is about 18" long and goes on the front of the door along the window frame. The other one is on the top rear of the door and is approx. 6" long. I had about $5000. 00 worth of hail damage fixed recently and the body shop, which is at a 5 Star Dodge dealership, says that Dodge does not offer those pieces as replacements. I find that hard to believe after seeing the importance of them. What's happening is that they have to adjust the doors so tight to make up for the absence of the strips the door is almost impossible to close without slamming. If the door is adjusted where it closes properly then every little bump of shift of the cab causes the door to squeak. In both cases, I have wind noise at about 55mph at the top rear of the door. Surely one of you guys have run into this. Any help would be greatly appreciated.
Thanks
Thanks
