I had the same problem on a 96', also with low voltage, and no tach. Thought possibly a ground issue. After a lot of looking found a bad connection at the ECM. I could duplicate the problem by wiggling the connector at the computer. Pins were corroded ended up replacing the module. Hope this helps.
