I have a '95 2500 with 160,000 miles. For the last few months, I have had to manually push up the fuel cutoff solenoid with the ignition on to start the truck. I did swap the relay, but it still needs to be manually actuated. The boot seems long gone, so I assume I need to take it apart, clean and lube it, and replace the boot.
Today, the truck would not shut down after I turned off the ignition. From other posts, it looks like this could be related to a sticky shutoff solenoid. I can get the truck to stall by turning off the ignition (the truck still runs at this point) and then putting it in gear - it will stall. However, if I start it back up and then attempt to drive (with the ignition on), I have no power - I can get up to 40 - 50 mph on a flat road, but more like 10-15 mph on a hill. This just started happening with the won't-shut-off problem.
Are those related? I don't rely on the truck for transport, it's more of a special purpose thing for me, so it also sits idle for a long time. My brother recently added some home brew diesel (tank probably has a 50/50 mix) and I've heard that might act like a solvent and clog my filter - I am wondering if that could be related to this? Or do I need to just tackle these one at a time - fix the sticking fuel shutoff solenoid first and then see what happens?
Tom
Tom
