Running boards
Running boards
Paint Job
I am looking for some running boards for my truck. My wife has them on her tahoe and they are nice to knock the snow off before getting in. I looked under DeeZee and was told they are no longer available. Any suggestions? Anyone had problems tearing them off in 4WD applications? Any
information would be appreciated.
I have the fiberglass aerodynamic boards that run from rear bumber to front and painted color of my truck. I was going to but them from a local trim shop than decided to contact the manufacturer. Locally they were 120. 00 plus S&H for rear pair, but when I contacted sales@prestigious1.com, I was able to get them for $82. 00/pair plus S&H. Don't know if your interested in the fiberglass one's, but this might help. When you find the one's you want, you might also send request for price comparison to www.carparts.com.
Good Luck
Bill
My truck came with DEEZEEs from front wheelwell to rear wheel well, I don't go 4Wheeling but I can tell that if you get off road very much they would get torn up, they really widen the lower portion of the truck.
I'm contemplating larger tires and wheels and it looks like I will have to modify the front end of the running boards or the tires will hit(even if I only go to 265's)I'm leaning towards 285's or even 305's but I need to get skyjackers 2"lift for the front first I think.
Hope this info helps.
Caleb
1993 LE W250 4x4 CC,Auto,3. 5's,LS. . Diamondplate,PowerWagon injectors,K&N,Egt,Boost,trans temp VDO Vision series, BD 3 1/2" Exhaust, 16cm housing,Mag Hytec Diff+ Trans pans,Transgo TFOD shift kit,Roadmaster Active Suspension.
Caleb Reese (per forum guidelines)
