2nd Gen Non-Engine/Transmission Running/Hazard [or CHMSL/Hazard] Lamp Wiring Diagram...
For those that are technically challenged! :--)
Adding this for center third LED ID bar, front and rear. Outside LED ID bar's will be running light/turn signal. :cool:
Out of curiosity are they going to be directional in some way or simply blink when the flashers are on? If directional how are you doing it?
Running Light's and Directional's...
Left and right LED ID bar's are running light and directional (second wiring diagram). Center LED ID bar is running light and hazard (first diagram). Will require two relay's each for left and right directional. Three relay's for center hazard. Side marker's will be tied in with left and right LED ID bar's.
Both wiring diagram's have Running Light's in upper left margin. TDR banner cover's the JPEG.
