I towed my Bronco about 400 miles this weekend and my Ram was running pretty hot.
It was almost always on the line at the top of the normal range. I'm guessing that's about 210. When I was pulling a long hill it would sometimes peg the temp gauge to 240. If I got off the gas, after 5 or 10 seconds it would drop quickly back down to 210. There were a couple times I had a semi right on my a$$ and I couldn't slow down so it was up there for about 30 seconds.
I found that turning the a/c off helped a little bit, and turning overdrive off on the hills helped, but that limits my speed on hills. It was in the low 80s outside which I'm assuming was the major contributing factor since the last 3 times I towed it didn't do this. That also made it pretty hot when I turned the a/c off.
I checked the coolant and it was full, but a little dirty. . I'm going to try a flush and fill and see if that helps any.
What else could be wrong? Am I always going to have to turn off overdrive to make it up hills without over heating? That seems like it puts me too close to red line just to keep up with traffic.
My friend has towed with his 97 a lot more weight and a lot faster without trouble. I know. . I was following him in my Bronco and I couldn't keep up on the hills!
Mine is a 98. 5 (Jan 98 build date), 24v, auto, 4. 11 gears, stock tire size and no bombing. Currently at 99,550 miles.
I need to figure this out. . My friends with powerstrokes were pulling away from me when I had to slow down!
