running in-tank and block mounted pump in series
About a month ago my transfer pump started going south so I took it to the dealer and they replaced it with the in-tank retrofit. I was not satisfied with the pressures, like all of the other posts here. I have the campaign pump that cummins released several months back, so I installed it in the original location and I'm now running both pumps in series. Oh man what a difference! For once it runs like it is actually getting fuel. This is just a temporary fix until the weather warms up. I purchased a used fuel tank module off of eBay so that I can remove the in-tank unit. Will the harness still plug into the old style module? I would like to install the glacier system and the draw straw. What kind of problems will I run into or need to plan for before doing this project?
