1/2 inch which I got at NAPA. I used zip ties of course! Also sections of heaterhose, I think 3/4" slit down the side in high wear areas. From the heat exchanger I ran the front line forward to the cooler by the radiator on the passenger side of the block then from the cooler back to the rear(inlet) fitting on the transmission. That gave more room for the lines than both together to the heat exchanger, then back around to the cooler. The rear inlet allready had a barbed fitting installed for rubber line attachment. Front outlet I replaced the factory line with one from NAPA with the checkvalve in it. I've read some folks think the valve restrict flow, but the guy I talked with at Goerend Transmission said that was not the case. Figured he had more experience on the matter than I...
Zips hook to whatever brackets I could, even reused a couple original transmission line retainers that weren't rusted off. (NY salt)
Temps so far haven't gotten over 160, towing landscape equipment up our local hills daily, a couple days in the upper 90's, I think my body temp was hotter than the transmission.
