Rust Doctor rust proofing
Tire Load Range-
Michelin tires LTX A/S vs A/T??
sfritts
Has anyone used the rust doctor products on their trucks? Mine is starting to rust in spots underneath, and have been looking at different coatings that I can apply. I have seen some of the jobs done by the so-called professionals and wasn't impressed at all. Some don't even clean the underside at all, and just spray it around on everything mostly the exhaust pipes and on the outside of the truck. :mad:
I had a truck of mine done by Rusty Jones once. It was a body shop that also did the rust proofing, they did a really good job. Specifically told me to drop it off before they closed on a Friday so they could clean the underside and let dry overnight. I watched as they put it on the lift and pressure washed it. The next morning before they opened it was still up on the lift. Before lunch they called me and said if I wanted to inspect before it came off the lift to come on in. It was a great job. They papered off the exhaust, trans, 4X case & etc. Just goes to show like paint work, prep work is the key.
