Today I replaced my rusted steel brake lines with Fedhillusa brakelines. I am a newbie with brake lines and this was not as difficult as I thought it would be.
This project started due to my rear brake line rusting through and rupturing under the driver seat area. I found out while inspecting the broken line that this line was spliced by the previous owner with brass plumbing fittings and unflared brake line. :-{}
I am glad that my brake lines broke before camping season so my family was not in an unsafe vehicle.
I decided rather than dropping the gas tank to route the one piece section to the rear fitting above the frame rail. I have also wrapped the line in rubber tubing to keep it from wear and tear.
Fedhill brake lines are so easy to work with and their flaring tool was so easy to use. Fedhill will rent the flaring tool for $25 so you dont have to buy it. If anyone is considering replacing their brake lines you should consider Fedhillusa because the brake line can be bent by hand, at extreme angle without kinking, and will not rust. Thanks to TDR member Dave who had the brake line fitting sizes documented which removed a lot of the brain pain for me.
