Thanks to everyone.
I checked the voltage at home with the trailer plugged in. 124 v. It would still growl. But would not start. I always felt it might be voltage to low.
After reading the one about the fan, etc. I was able to use a push rod through the vent to try and move the fan motor. It still would not start.
I went online to a chat person with Dometic. He said that some of the units during that era, the fan motor had a dead spot. I rotated the fan one more time and used his suggestion to set the thermostat as high as possible, turn on the AC, see if the fan runs, it the fan runs, move the thermostat down to 78 degrees or so and see if the compressor comes on.
I did that sequence and it now cools.
I'm going to check with dometic about the motor and a possible recall and see if I can get any relief.
I also sometimes think I will win the lottery!
While the AC was running, the voltage in the outlets in the trailer were 107.
