I am in need of a new battery for my slide in camper. Are any of you with campers using the new Odyssey dry cell battery? The Amps for those batteries appear to be much higher than for lead acid deep cycle batteries, but how does the reserve capacity compare? The information I have seen lists the Amps but does not list the reserve capacity. Summit Racing list an Odyssey rated at 1,200 amps for only $15 more than the Optima Yellow Top rated for 650 cold cranking amps but again does not list the reserve capacity. The battery I presently have is a Action Pack marine/RV with a 115 amp HR rating. I also need a battery with the stud /wing nut terminals. I have electric jacks on my camper so if I set the camper off and let it down it takes a lot of power to get it back up. Also not having to remove the battery from time to time to check the water would be a very welcome plus that comes with the Odyssey or Optima battery. If you have any comments positive or negative about either battery please either email or post your comments.
