We managed to kill the battery in the slide in and started looking into a new one along with solar panels. We've calculated our amp hour usage to be around 63 AH and are looking at 2 panels totaling 150-175 watts based on these numbers.
I've been told i shouldn't discharge a standard deep cycle battery past 50% of it's capacity as the recharge times can be longer than what i can expect to get from the afore mention panels.
Looking at batteries i've found dry cell batteries that don't mind deep discharges with a 65 AH rating. Gel cell batteries have a 55 AH rating and the big Sears Diehard has a 115 AH rating. Using only 1/2 of the deep cycle battery gives me about the same capacity as the dry and gel cells. Sound correct?
Questions:
How well do the dry cells recharge after a 70-80% discharge with the above panels?
Same question with the gel cells.
I like the idea of the dry and gel cell batteries since we could add a second one inside the camper and not have to worry about gas problems. This would give us 110-130 AH capacity.
Were setting up for future trips where we'll out of touch with civilization for several days at a time and want to make sure we'll still have lights and heat.
Thanks
Brian
Questions:
Thanks
Brian
