RV trailer plug instaaled in the bed
WINGS
Who has an Equal-i-zer brand hitch?
For those of you who have installed the RV trailer plug in the bed where did you tie the wiring harness. I called a local rv dealer ship and asked them how they would do it. The service tech said that they you use scotch locks. It seems to me that the proper way would be to run the cable or wiring harness back to the existing rv plug and tie in their using solder and heat shrink or mount abox with a terminal block and tie all the wiring on the terminal block. What are your thoughts and opinions?
My bed jack is connected to the wiring for the license plate jack. I solder and shrink tube ALL my electrical connections,I've had too many Scotch-Locs and crimp connectors fail. Sometimes if it's a hard place to work on I use an uninsulated crimp connector,crimp it to hold the wires together,then solder it. You will have hard finding an installer who even has a soldering iron nowdays though.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,BD E-brake,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
ROG,
On my '00 I ran the 7-way cord around to the factory plug under the rear bumper. I did run a seperate 8 gauge 12 volt charge line from the driver side battery through a circuit breaker and a relay controlled by the ingition switch to isolate the starting batteries from the RV battery. The factory 12 volt charge wire is too small and doesn't have an isolating relay. My Lance camper has a 3-way fridge and it draws about 15-20 amps when running on 12 volts.
On the 97 that I had, I tapped into the short harness that runs from the main harness to the factory plug soldering the connections and using heat shrink tubing.
No way is anybody going to use Scotch-Loks on my truck!!
Bill
Y2K 3500QC, 6 Speed, 4. 10, SLT+, Camper & Tow Pkg. , Westin Chrome Nerf Bars, Mopar Flaps, Reese 20K Hitch, EGT & Boost Gauges, RPM 45 Gallon Aux. Fuel Tank, Highway Products 5th Wheel Toolbox, ECM Controlled PacBrake, Painless Wiring Kit, Mag-Hytec Diff. Cover, Rancho 9000, Air Lift 5000 Air Bags, TOYS: '97 Hitchhiker II 31' 5th Wheel, 2 slideouts, 19,750 GCW, '94 Lance 990 11' 3" Slide-In Camper, Torque-Lift Camper Tiedowns
I also will not use scotch locks. Im ordering my 5er this weekend so I will be wiring my truck in myself. I will also be installing my own hitch. This is about the only way to make sure its done right. Im thinking about ordering an OEM plug. I will then cut the wiring,solder and splice the longer wires and then plug it in at the rear. If I ever haul a trailer than all that needs to be done is unplug the 5er wiring and plug in the trailer wiring.
2001 HO 6spd,Quad cab,LWB,4x4,Flame Red,all options except for leather,Westin Brushguard/Push bar,Painless wiring,Radio Shack CB,my own design CB mount,Smittybuilt nerf bars,NW Custom rocker covers,Custom built stainless rocker light bars,DeeZee bedrails,Isspro pyro and boost gauges(more to come)
The genltman I bought the truck from relocated the factory plug into the bed. He cut the inside of the box side and mounted the factory plug there. Originally I didn't like this setup, but I have made my 7 to 4 and 7 to 6 way adapters long enough for everything to work out fine.
[This message has been edited by Cooker (edited 02-14-2001). ]
Mine is in the middle of the bed (92 D250).
Dedicated wire from the tow controller for
the brakes, new lead thru a relay for
running lights, small hole in the bottom
of the bed.
The 5er's cable lays in the bed very nicely.
92 D250 LE ClubCab, pump-tweaks, tach/pyro/gages, 16cm2,
A518, 3. 54, LSD, TowPkg, SuperDuty cooler, RBW 5er hitch.
00 Jayco 27' 5er
I soldered and sealed all wires into the existing trailer hitch wiring harness with the exception of the Battery and Ground. These two wires are separate 6-gauge. The Power is activated by a solenoid switch (ignition on) and the ground includes a 0. 01-ohm shunt so that I can monitor how much current the camper is pulling.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins (ETH), 6-Speed (DEE), SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine + diff. temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper. "Do it in a Dually"
I installed mine in the side of the bed. I drilled a hole and mounted the 7-pole flat in the side. I ran a 5' pigtail and plugged into the existing harness on the factory hitch. Works fine.
Shane Oler
'01 2500 4X4, ETH/6 speed, Pyro (pre-turbo)and Boost Pillar mount, Dark Garnet/Camel, 20K Reese 5er hitch
Other: '70 Olds Vista Cruiser 455 (future resto project)
30' Sandpiper 5er Super Slide bunkhouse(about 10k lbs. )
I didn't want to cut, splice, tape, solder or otherwise damage the factory wiring so I thought and thought and thought on a way to do this cleanly to my '97 1 ton and then it hit me... No way I thought sounds TOO easy...
I just unplugged the factory 2 plug harness, took out the 4) 1/4" screws holding the factory female section to the bumper, drilled a hole in the bed between the tailgate and wheel well, dropped the wiring down the hole and plugged it right back into the factory harness which runs right along the drivers side frame rail.
Then in a stroke of luck found a factory harness on another truck in the bone yard. (My dealer wants $95. 00 for the factory plug setup) so $5. 00 later I put the "junk one" back into the bumper location. Now I just swap the factory harness plugs to what ever I am towing, gooseneck into the bed & tag to the bumper. This also avoids having to crawl up into the bed under the gooseneck just to plug it in!!
A word of caution, check the length of the wiring BEFORE you drill the hole so you don't place it TOO high!!! Mine is about 5" above the bed but measure, measure then measure again before you drill...
Hope this helps... Did for me!
