Check out Eley Hose Reels.
www.eleyhosereels.com
The Eley Hose Difference
There are many attributes that make our hoses top of the line and worthwhile additions to any garage. One of the largest differences is the material we use for our gardening hoses. Polyurethane is highly resistant to cuts, punctures, and tears. You can drag it through rocks, over cement, jagged landscaping stones, and thorny bushes and it will still be unscathed. You can even drive over the water hose to really test its unbelievable strength! The polyurethane is two times lighter and three times stronger than other leading water hoses. It will be easy to pull throughout the yard or garden without the need to "fight" it. With this, our FDA-grade virgin polyurethane is drinking water safe. All materials, including the rubber gasket, meet NSF 61 standards and are lead, BPA, PVC, and Phthalate free. This material is also mold and mildew resistant, so you can store it virtually anywhere necessary. When you or the kids want a quick drink from this drinking water hose, you can trust in the hose's quality and Eley's commitment to safety.
You've likely had your garden hose kink, forcing you to trace the length of it to release it. With our durable garden hose options, you won't have this problem ever again! Our hoses are crafted with high-tensile threads woven into a "chain-mail armor" pattern. This results in superior burst strength and kink resistance. Unlike other hoses, ours have ZERO kink memory. The fittings on these polyurethane hoses are lead-free brass and have a commercial-duty crush-proof design. They're built with advanced technology to never leak, and these also have full-flow crimping. Rated to 150 PSI and ready to work from -40°F to 165°F, the Eley garden hose is a must-have for avid gardeners, car enthusiasts, plant lovers, and all other who need a high-quality garden hose at home. We offer these hoses in a 5/8" option and a shorter inlet hose that acts as a feeder.
