And I don't think you will see maximum boost unloaded. bgRVKeuren said:I have a 1993 dually one ton club cab 4X4 with 230K plus miles. I'm only getting 13 # boost out of the turbo and was told by Dodge that it is what is suppose to be. I had read somewhere that the boost should be 19 #. Which is correct???
Philip said:Mine will do the same on boost empty or loaded and on flat ground.![]()
Philip said:and on flat ground.![]()
