2nd Gen Non-Engine/Transmission RWAL valve, where to get?
Mechanic's mechanic called around looking for one Dodge told him they were obsolete. 96 (Mule) rwal valvel right under master brake cylinder with a connector. The mechanic has a Ram and happens to have a used one he got at junk yard just wondering if there are any aftermarket ones or if Dodge used this valve on other models?
I have one on my totalled out '95 that was working fine. It's a '95 2500 RWD auto with rear anti-lock only. Let me know if you'd like to get it and I'll take it off when I'm at the truck this weekend. You tell me what it's worth. I have no idea. Used parts typically sell for 1/2 of what a new one would cost.
Scott
While I'm not certain, I'm pretty sure most larger vehicles, such as the Caravans and Full-size vans also used this type valve for a short period of time..... and that's only on models without four wheel anti-lock, which I'm presuming you have.....
I think the part number is Cardone 12-2034..... that's not for the 4 wheel antilock..... so I thunk... .
Thanks for the info HHhuntitall ( I thought it mite be used in other vehilces from Dodge) and GOlsen ( I will check it out soon).
The used one is on and working great. Apparently a cap came off and that was where it was leaking from. Bill/ Missouri Mule
