S&B CAI issues
Edge Insight Q's
Turbocharger Speed Sensor Circuit Performance
Good evening folks,
Just installed the S&B CAI on my 08 2500 and followed the instructions that came with the Kit. Once all was back together I went to start the truck and noticed that the CEL stayed on. Pulled the codes and three came up
1. P2228 Barometric pressure circuit low
2. P2580 Turbo speed sensor circuit low
3. P1193 Inlet air temp sensor high
CEL went away after a few start ups but i was wondering if any one else has installed a CAI and had issues or is this normal to get a CEL and codes after a CAI install? Also if the CEL is gone does that mean the codes are cleared and the issues are gone?
Thanks,
Will
sag2,
I believe I may i have done this. I went and doubled checked my connections and realized the air temp sensor was not connected fully (tight spot). I will assume this is my issue, thanks for the reply.
Will
