What settings can you run on the street w/o breaking 1400° when trying to move out smartly? That's where I have the defueling point set. I'd like to try to keep it below that.
I can't seem to run over about 5x3 on my original twins flash (no pressure) without the TST defueling. If I do a 2000rpm 4th gear roll-on, I'll hit 1400 before redline in 5th. My Quad Race felt stronger than the TST with these settings.
I have an AFE stage II, Banks Technicooler, ATS manifold, FASS that maintains about 16psi at WOT. Not sure what the deal is, but it seems to me I shouldn't be getting this hot this quick.
On a Dynojet, I made plenty of power with the original program on 7x7 and a BDDL on tow. Seems to me I could run higher settings on the street, too.
I talked to TST, they told me that 7x7 is the same on the regular flash and the twins flash. The only difference is that the fueling starts earlier (4psi vs. 11).
What are you guys running? What are your EGT's?
I don't know, maybe I'm just used to the power. It doesn't really impress me any more. What do you suggest?
