After a lengthy discussion with Mark at TST, the problem was determined you CANNOT use the edge elbow as it will not allow boost to bleed off,with the Edge elbow he estimated the turbo spooled to 65-70lbs. and boom it went to turbo heaven!Save yourself a few hundred bucks and install the correct elbow, learn from a couple of AZ knuckleheads what you can't do.
TOMEYGUN,hats off to ya,you were right on the money!!
Alan in AZ
Alan in AZ
