I'm about to install a '94 12 valve. It is out of a wreck, appears to have been a front collision. I don't know much about it, its been sitting in a warehouse for a few years & there's no one to ask. The fan has some bent blades & the water pump is locked up.
The engine sits nestled in a pallette on the back of a trailer. It is merely strapped down. I took it to a local diesel guy to get it started up & hear it run before we drop it in. He tried jumper cables directly to the starter, but it has so much torque that the engine rocked hard & almost turned over.
He said hearing the engine run won't be an option until it is mounted in the truck, but he thinks it will run fine. He's recommended we swap out some parts while the engine is out. He said he always puts in a new oil pump & bearings when installing a salvage engine.
The oil filter looked clean, barely any signs of metal shavings. The engine had 94,000 miles on it, supposedly ran before it was pulled. It has a 160 pump & complete electrical harness & computer.
Is he right? Do bearings need to be replaced? Do these oil pumps go out around 100k? He said the engine pretty much has to be pulled to drop the pan so now is the time.
Are there any other parts i need to service while the engine is out? I am on a very limited budget & hope to get the engine swapped this weekend. Should i mod the 160 pump or just wait & save up for a good 215 later on?
Thanks,
Matt
Thanks,
Matt
