Engine/Transmission (1994 - 1998) Sasquatch Discovered at Cummins
Mike Ellis
(UPI) Zoologists were extremely excited today to report the discovery of Sasquatch (AKA "Bigfoot") at the Cummins Mid-Range Engine Plant today. After decades of controversy over the huge primate's existence, irrefutable evidence was obtained today by a news crew visiting the plant.
According to Cummins officials, the 8-ft tall, 575-lb beast has been employed at the plant for several years installing starters, oil pan drain plugs, and oil filters on Cummins 5. 9L turbo diesel engines. Dodge Cummins truck owners who have speculated for years as to how the manufacturer attained the incredible torques these assemblies exhibit, may finally rest easy knowing the truth at last.
Plant co-workers indicated that the beast is quite intelligent and during subsequent interviews it was learned that he actually speaks English, albeit with a thick German accent. He is reportedly quite excitable, rather set in his ways, and violently opposed to the use of torque wrenches. "We gave him a torque wrench, but he just uses it to kill rats. He got kinda mad when we asked him about it, and threw an engine block across the room. We decided he didn't have to use a torque wrench unless he wanted to," said shift supervisor Lars Poker.
In an exclusive interview, the hairy giant was asked what technique he favors for installing these parts. He replied, "Yah, I tightens der bolts mit der fingers undt den I give him big uggghh with wrench. One uggghh getting him pretty tight I tink... . "
According to Dodge CTD owner Mike Ellis, who recently changed out his starter contacts, one "uggghh" on a starter bolt appears to be the equivalent of 400 ft-lbs. Mr. Ellis will soon undergo surgery to shorten his right arm, which was stretched an extra 1. 5' during the gargantuan struggle to loosen the bolts on his starter. Said Mr. Ellis, "I knew I was wrenching pretty darned hard when the truck flipped over on its side, but I didn't know it was because the bolts were Sasquatch tight. When he uggghhs, he really UGGGHHs!"
When asked if the bolts really needed to be that tight, Cummins officials said, "A tight bolt is a happy bolt. "
Fantastic story!!!! And all this time I was blaming myself for getting older and loosing strength... ... ... . Damn, I'm feeling better already... . Hmmm, Oh, mama? Where are you?????????? :D
I actually laughed out loud at that one!! My elbows agree with the discovery. :D I believe that's the funniest thing I've read on this site; well done!
Thanks for the laugh Mike. :D
Now i know why that first fuel filter and oil filter change was so darn hard to do, those things just didn't want to come loose. LOL. . great story that was pretty good...
Thanks mike!
now i know which big harry sob tightened down the 8mm plug that hides the star wheel on my 97... ..... i will be damned if i did not have to use a 3 foot cheater pipe with heavy force! damn sasquatch :)
Ah, yes-- the German torque method, "Goot 'n' tight!" Tell ya' what, though, it beats all Billy Buckshot out of having to have a chase car follow you around picking up pieces that fall off as you drive!
Brad
