SBC MU 0090 Con O Towing Capacity?
steering shaft install question
Help
Wondering if anyone is running the SBC MU CON O clutch with about 300 to 350 hp? If you are do you pull any heavy loads? How does the clutch do? Does it slip at all? I would never pull anything over 15000, but wondered if I needed to upgrade to something better. Thanks.
Brenton
SBC recommends the stock 13" Sachs clutch for towing. It is good for that HP range you mention. I bet that MU Con O is a smaller 12 1/4" job. Towing you better look at their 13" Con OFE or FE clutches. I have the FE but I don't tow. It is smoother than stock. Softer pedal as well. I have not broken it in yet to test it out though;).
