Well guys, got the SBC 13" OFE in this weekend. Overall, the job was pretty easy. I guess the hardest part was getting the transmission back in and lining up the shaft with the throw-out and clutch splines. Had to jack up the front of the engine enough to get it at the right angle to slide the thing in, but it eventually went in.
Thing I am paranoid about is the rear main, as I didn't have an alignment tool to for the housing, but after centering it with the seal, all the teflon seal surfaces were visibly touching the crank and the crank was cleaned up real good and dry with plenty of brake cleaner, so I am crossing my fingers!
As for the clutch itself, the pedal feels a bit more squishy and like it has more play in it, but it seems to engage at about the exact same point as the old clutch. I guess that pedal feeling should go away as the clutch breaks in, as I remember from my other new clutch replacements that the pedal felt similar. Just need to get it broke in so I can start hammering the go-pedal again and see how good she holds. I don't have near the power it is rated for, but all I need now is some 370s and a B1 and I'll be much closer to the rated power for the clutch. Plenty of room to play with though and not having to worry about the thing slipping anymore is a good thing. Oo.
Joe
Joe
