RSimmons,
For the benefit of the rest of us it would be great if you filled in your profile so what could see what truck you have and the current mods. For example, if I did not see a fuel pressure gauge in your profile that is the first thing I would recommend, even before replacing the VP.
Scheid builds a great pump, that is how they got where they are. The Lightning would be a great addition for power
An AirDog would also be my two cents for the lift pump department. Again, if you have a fp gauge and your lift pump provides an adequate supply of fuel TO THE PUMP then run it till it goes bad & then install an AirDog (pm me for dealer contact).
The edge EZ will be better than nothing but I would HIGHLY recommend Smarty. If you already have the EZ then use it. When ready for more go with Smarty (pm me for dealer contact).
Sounds like you are on your way to a much bigger grin while driving your truck!
Godspeed,
Trent
