ok guys i need the dimensions from the back of the block. there are 6 bolts that hold on the plate that the bell housing bolts to. what i need is the measure from the center of the crank. if you were to go straight out to the side like 3 o'clock and then measure up or down for the bolts. And then from the 12 o'clock position to the right off the center line. this would be greatly helpful. A drawing with dimensions would be much better. Thanks in advance guys.
The Fat Kid
Andy
The Fat Kid
Andy
