Dyno numbers?
First of all, this will be about the Ram Air 3 since I am the developer of this product. [With the help of Rod and his truck]
I have always had my doubts on how an air intake can increase HP on a dyno. We had the opportunity to see that there was one horsepower difference between the stock box and our RAM Air 3 on a dyno at a DTR rally in Virginia last weekend.
No surprise to me.
The Ram Air 3 is also an enclosed system that blocks most of the underhood engine heat from getting into it.
Here are some of the results folks are giving us...
Empty stock truck
- Improved mid range throttle response
- 50 rpm lower for the same speed.
- Faster EGT cooldown.
- cooler overall EGT's by 50F or greater.
- claims that it 'woke up' the truck compared to the stock box are very common.
Pulling a 34ft 5th wheel
- driving the same hill with A/C on or off they shaved of 8 seconds on their acceleration time! I was skeptical of this... four runs after my skepticism proved it was a true claim and another gentleman saw a similar result... 7 seconds quicker!
- Could not press the EGT past or even hit 1200 at WOT in 6th at 55-60 MPH and could not accelerate anymore and still kept the egt in check.
- Mileage improvement of 1-2 MPG is becoming a common result.
Rod and others that have done some power mods can chime in here on what the results are for them. So far this unit is giving more results then the Scotty Air II did for the 2nd gen trucks.
