Scotty II question
Product Support?
Toyo M-55 wear patterns
Has anyone else noticed an increased peak EGT after installing a Scott II? My may egt went up ~100 degrees. Runs cooler by 50-75 when cruising but hotter when accelerating fast.
Do you have the UNI, K&N or the AFE filter??
I have the UNI. hole cut in cowl. I noticed a pretty significant peak drop. I had the 10 plate in, slightly foward before the scotty II. I could hit over 1500* in 4th gear, not sure how much over though cause thats all my gauge reads.
With the Scotty and plate in same location, 4th was right around 1400*, so I saw at least 100* reduction.
Now that I have more fuel and different turbo, the scotty works even better I think. I love it. I wish it was even louder.
--Jeff
A year?? Seriously?? heck, I usually wash mine, let it dry, and then oil it and run it shortly after.
I think if you are oiling it enough for it to drip, thats way to much oil!!! Just my opinion... I dont use much oil.
