Cut the hole in the firewall for the end of the Scotty II. I don't want to just "cover it unless you need it" because when I need it towing it will be there.
The whine is fairly significant unloaded cruise and really significant when accelerating hard. Tried A/C on and off, outside vent on and off to see if there was a setting that was acceptable. Nothing I tried helped.
I thinking something like a fitting into the 4 1/2 hole that would make the turbo pull air from the vent to the left (left looking from front to back). Something like a 4 1/2" PVC coupling with large holes drilled in it positioned so the solid side is to the centerline of the truck and the holes are to the outside.
Has anyone worked on getting the trubine whine out of the air intake system with a Scotty II?
Thanks
Bob Weis
Thanks
Bob Weis
