Scotty Or Psychotty....."But That's One BIG Hole To Cut !!"
Teeth Grille
factory fender flares
Ok... . I've Gotten A Scotty air setup in the Beast... Even got one of those Fine Mesh Black Socks over it to keep the "Fines" out. .
But I Gotta Ask... .
I'm the kind of guy who Finds a scratch in the paint and needs a month of Crisis Management to get through it!!!
If someone parks too close I take TWO Prozac!!!
(Ask The Wife... She'll just roll the eyes... )
After all we're talking about a $30,000 truck here!!!
How did you guys work up the NERVE to cut that 4" hole for the Psychotty Air System???
MY GOD!!!!... You can stick your whole FIST in it and not touch the sides. !!!!
If you needed to . . you'd play HELL sealing it up again!!!
Those IRREVERSABLE ACTS give me the Willies. .
Ok... . I'm Coming in from the ledge now.....
Talk to me!!!
Larry
Actually ... where you cut the hole... isn't that bad ... I don't have Scott's setup yet #ad
I'm still miffed about the lack of the filter minder ... Scott sent me an e-mail about it over a month ago and I agree completely with his logic ... not to mention his tests. You can always pop rivet something over the hole when you decide to part with your favorite toy. I would keep the piece of insulation and put it back. Unless the buyer is savvy to mods ... they wouldn't know the difference. IMHO
Life is good!
'95 2500 Stretch 4X4, Auto, 265/75/16, white. TST #5 250/635 plate, 215/230 injectors, K&N, Cummins chrome, BD Valve Body, Pro-torque LS convertor, mystery switch, JRE 4" turbo to tailpipe w/ monster tip, ISSPRO boost and pyro, Pioneer CD system, Galaxy 99 CB w/ 400 linear, nerf bars, Rancho 9000's, 8K tag-a-long RV ... Life is Good!!
[This message has been edited by Rammin On (edited 06-26-2000). ]
<font color=green>Larry. . am with you... there was jus a lil discussion on the cough cough #ad
12 valve forum... i could never do, my truck is a lil over a year old... . I did the same... . pointed out that our trucks cost in an excess of 30g's... . I figured i can take the mods off if i wanted to sell or trade it in... IMHO
99 Quad,Long bed,4x4, SLT,Auto,K&N,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump, Suncoast coverter,BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, "true" Jet-Hot Coated 5 inch exhaust from turbo to tail pipe(over the axle)Borla shoot-out muffler,DD stage 3 injectors and boost module,HX-40 16cm,here and waiting to be installed, Next Jet-hot my ATS exhaust manifold and turbo housing, and special thanx to rob for swaying me on a 4 wire Blue Box(incoming)
[This message has been edited by QuadDoorRam25004x4diesel (edited 06-26-2000). ]
Wait 'till you go to cut the hole in the middle of the roof for a CB antenna! For them to work efficiently, the middle of the truck, on the roof is considered the optimum location! Has to do with "ground plane". I too was/am nervous as heck, but I'm gonna have to get over it if I want the radio to work at its best.
2001 QC Dually SLT+ 354 LSD AUTO 4WD Driftwood SS Railcaps Stainless Werks step-rail nerfs Rhino spray-in liner Aux B/U lites Diamond Plate Alum Highways tow box SS Fender lips Jardine 4" Mag-Hytec diff & transmission Alcoa classics Reese 20K hitch 28ft Holiday Rambler 5er w/slide 84 Scrambler 4" lift 33/12. 50's 4. 56 gears soft locker/trac-lok Built 258 w/Mopar fuel injection conversion BUILDING 66-442 Olds, ground up--OH BABY! NRA 25 YEAR MEMBER
Don't be such a bunch of wusses! How bad do you want it? Well, get out there and go for it! You can't heal unless you cut steel!
Otherwise, call me or Evan Beck-"The Sawzall Brothers"! (specializing in induction and exhaust system surgery) Just do it!!
Bill Lins Wharton, TX 98 2500 QC SLT,12 (the CORRECT # of)valves,NV4500,3. 54 LSD,Manik grille guard,Psychotty Air,Amsoil everywhere, Reading aluminum utility body and bumper,Optima yellow tops- silencer ring, cat,& muffler all stolen.
Come on you guys,that 4 1/2 hole is easier than the little one for the pyro sender. If you haven't done that you don't need a Psychotty anyways.
Now where do I put the valve for the jacobs brake. I don't think i should put it in the hole.
2001 6-speed 4*4 Quad dually. Diesel Dynamic Injectors, 14cm housing 4in exhaust. Jacobs brake.
Hey wait a minute Bill! Mr. Sawzall (a. k. a. NW Punk) hasn't worked up the nerve to cut the 4. 5" hole in his new '01 Ram yet. LOL
Come on over Evan, I'll blast that hole in your cowl for ya... no charge either... the look on your face while the chips are flyin' would be payment enough for me. #ad
Hey, maybe I could do Mike's cowl at the same time... Yeehaw, let 'er rip baby! #ad
About half way through the cut... Suddenly stop. . pull back and say... "OOPS... . "
Now That's A High "Pucker Factor" event. !! #ad
I installed the psychotty air last night at work (on my lunch break of course). You should have seen jmbrowning's and my eyes bugging out as the 4. 5" saw bounced around and tore it's big hole! #ad
I guess there's no two ways about the install,but it seemed like hackery to me... . good thing the touch up paint matches.
Now it's time to find some dense insulation 'cause it sounds like the turbo is sitting in my glove box. The verdict is now out to see if it does what it claims
Maybe Evan was putting it off because the Garnet Red touch up paint was on backorder. I remember picking up the last one in the area... . but I'm done with it now,step up!
-Mike
[This message has been edited by MikeR (edited 06-30-2000). ]
I have to admit that I'd be timid with that kind of artillery, THAT IS A BIG HONKIN' HOLE! Mike has nerves of steel and will keep on blasting till he runs out of ammo.
Fortunately I can live vicariously by hanging around the BOMBers #ad
2000 F250 Reg Cab 2wd under-valved and over-cylindered PSD 6spd. (I know, I made a mistake)
Like a challenge? Try IPSC Shooting. Check out http://www.uspsa.org
C'mon, it's not like you're cutting a hole in the front quater panel. If you pull and fold back the iinsulation, if you ever decided to take it out and put it in your next truck, you could just patch it and cover it.
As for this system, it works well. I have consistently seen 100 degrees lower on the highway across the board.
The PSA is a no brainer. Especially with the many high priced mods out there.
96 Long bed EC, Banks Twin Ram, BD TC, BD EB, BD VB, Mag Hytec Pans, Warn 8000# winch, TJM Bull Bar, Speedliner, Katzkin Leather kit, K&N Filter, Trailmaster 2" Lift, 35BFG ATKO's, Kodiak Sidewinder Steps, Reflexion Cowl Hood, Autometer Guages, Horton Clutch Fan, PIAA Superwhites, Optima Red Tops, BD Pressureloc, BD Torquloc, Psycotty Air.....
