Engine/Transmission (1998.5 - 2002) Screwed up Genos hose while installing FP gauge--any other sources??
2nd Gen Non-Engine/Transmission New life for old plastic
2nd Gen Non-Engine/Transmission need RS 9000S replacement shock
Is the 18" hose Genos sells for the FP gauge install a propriety thing or can I ask for one at a parts house? Any idea what part number to ask for? The only number I see is the Dayco B704, but that references the hose itself.
Thanks for the help.
I screwed mine up by overtightening it to the schrader valve. I just dug out the plastic from the end of the hose and removed the valve core from the schrader then reattached the hose.
I have the Westach gauge, but I am using a sending unit. I did the same thing Rammer, but I was leary about removing the core. Have you had any problems doing that?
Thanks.
I would have preferred to leave the core for a dealer test port, but I have not had any problems without it. Removing the valve core is common for people who used a common grease gun hose instead of the Geno's hose.
Good Luck!
Bill
