Search features not working
search limits
Any word on the 20K member??
What is the specific error you are getting and what are you trying to search for? I just tried a search and it's working fine. More detail may help me pinpoint the problem.
Steve this is the error I keep getting.
Web Site Not Responding
The web site you have requested may be experiencing technical difficulties due to a busy or broken server.
Please try again by clicking the Reload icon on your navigation bar or, if that doest't work, you may want to return to the site at a later time.
504 Connection Timed Out
I am trying to find some info on changing out the front shocks on my truck.
I am using the search in the 2nd gen no engine and tyranny forum.
Hope this helps.
Thanks
MIKE
Try again a little later. It sounds like your having some problems with your internet connection. I just checked all the status information on the server and the slow query rate on the server right now is . 004% (or 5. 3 slow queries out of 128490 per hour). A slow query is defined as one that takes longer than 10 seconds. If the system was taking so long to respond that your browser was timing out it would be a much higher rate than that. Try again later and I bet you'll be able to do it no problem. Are you noticing the site being slow to respond to you as well? I would guess yes.
No Steve the site is actually responding pretty quick.
Later on to night when I shut this computer down and I fire up my other one I will try the search and see what happens.
In case i cant get the search to work is there any info on how to change out the front shocks on our trucks.
Thanks.
MIKE
Thanks for the info Steve. It is going to be a little easer than I had expected for the gronts. Thank God.
I did get the search to work and then it said it found no matches, I tried again and I got that same error message as before.
The link you sent me was grate. Thanks.
MIKE
Exactly what were you trying to search for so I can try to replicate your problem. What search terms, what username (if any), and what fields did you change (like which forum, view as posts or as threads, etc)? So far the two of you are the only ones to report problems. I need to be able to replicate the problem or at least have more data on what lead up to it to do anything.
-Steve
