My '96 extended cab has small cables that are supposed to cause the seats to slide forward for access to the rear when the seatback is tipped forward. The driver's side has always worked, but the passenger has not since I bought the truck in '99.
I removed the seats and tracks to clean, paint, and grease them (they sure get rusty easily!) and examined the cable problem. The driver seat uses an actual steel cable, the broken passenger seat uses a lousy plastic cable from which the end has broken off, and it must have done so when the truck was almost new. I know that plastic cable must have saved Dodge at least 3 cents over the steel cable, but I would like to splurge recklessly and upgrade and replace the plastic cable with a steel one like the driver side has.
Has anyone else replaced theirs? Is it available from Dodge or do they want you to buy an entire slide assembly? Is the replacement plastic or steel? Can it be purchased anywhere else?
While I'm on the subject, has anyone found replacement seat covers they would recommend?
