Seat belt light, 05 Mercury Gran Marquis
Need help finding a Tractor Part
Polaris ATV, 500 4X4
B.G. Smith
Light came on a few days ago. Had in shop last year for same thing and they replaced the drivers side seat belt assy. So I inspected the wiring under the drivers side seat, found one wire (black with white stripe) had been into the gears of the seat adjustment mechanism, did not cut wire off, it just nicked the insulation enough to cause short circuit. Taped everything up good and moved wire to try to prevent same problem again, disconnected the battery for two hours, checked all fuses with meter, ihooked everthing back up and still have light on. It flashes 3-4 then stays on. An ideas on how to reset light? bg
