Ok I have a 99 quadcab and recently removed the center console to place an amp under it for a new speaker system.
Long story short , there is a 2" x 2" (approx) black sensor under there that I had to unplug move and put back when done. Since then my seat belt light will not light up on my dash when the belt is not buckeled like normal. and when you slam on the brakes hard the belt will not lock. I have since gone back in there to make sure my wiring harness is plugged in all the way, and all is fine. I can hear something rattelling around inside this box. . ?
Ok, did i screw this thing up ?? does it need to be replaced and if so , what the hell is it called ... . thanks , Tom
