Secondary fuel filter recommendations?
Question re: ECM reflash/backup warning recall
Which Clutch to go with??
Two years and 25K miles ago, I bought and installed a CAT/Cummins dual fuel filter kit from Throttle-Up Industries, in Bend, OR. The kit mounts between the fuel tank and the factory fuel filter. There are two filters in it, one to separate water, the other to filter solids down to 2 microns. I figure adding these filters will significantly extend the life of the very expensive injectors at reasonable cost. So far so good...
Cloudmaster Don
Cloudmaster Don
I second this kit
Cloudmaster Don
This one looks good. I like the hard lines and minimal rubber. The only not so good thing is the lack of heating provision. The under hood filter kits will eventually warm up.
Cat filter users, I would like to direct you to AH64ID's post #15 in "Hanging idle after New Injectors and tubes no codes" by Darkbloodmon started 4/25 in this same forum.
