I installed a second oil pressure gauge to cross check the instrument panel OEM indicator. There are some significant differences in the pressures, especially when the engine gets warm (water tamperature stabilizes).
Anyone else with a secondary oil pressure gauge see this?
OEM / Secondary
Idle warm 35 / 25
50 mph 45 / 60
70 mph 45 / 70
cold idle 60? / 90
The secondary gauge follows the engine rpm really well. I have even tried to set a speed (after the transmission gets shifted into O/D) watching the secondary oil pressure psi and it is fairly accurate repetatively (ie 60 psi = 50 mph in O/D).
I am taking the sensor off the line to the bypass filter which is actually somewhat open as it returns to the oil fill cap. The pressures would be even higher in a closed system I would think.
Why do you think the OEM indications are so much lower, except for warm idle?
Bob Weis
OEM / Secondary
Idle warm 35 / 25
50 mph 45 / 60
70 mph 45 / 70
cold idle 60? / 90
Bob Weis
