Question(How To) for TDR experts;
Is it possible to install a heavy duty toggle switch that can be used to flash your lights to thank trucks for blinking (telling you are clear to move back over). I think you should be able to wire into the light switch for only the rear running lights and then to the toggle switch. The only catch in my mind is to be sure that you keep the toggle switch in the on position before and after you do your blinking "thanks" signal. Also, wouldn't that also hold true to if you were pulling your trailer. I would think that if you wire the toggle to the master switch area that where every the trailer light splice would have been it should take care of that as well. Hope this message makes sense. The reason I would like to do this is that now when I thank the truckers, I have to shut off the light switch and of course that means that the headlights go out for a second or two.
What are your thoughts and any guidance you can give me on doing this right?
Thanks,
bob Caldwell
Thanks,
bob Caldwell
