I have an oil Leak. . It is dripping off the bottom between the bell housing and the oil pan... and is Oil. . I see it dripping down from the right rear corner of the engine block, pass side... Seems to be dripping down there and behind the oil pan and off... I checked behind the valve cover and it is a little dirty but not wet. . Head Gasket??. . It is wet below the outlet of the #6 port of the Exhaust Manifold. .
Is there a commonality for a leak at the head in this area? (pass side rear). . I had the engine rebuilt around 40K ago and I do tow heavy a few times a year... I try not to get the engine too hot and I do have a engine oil cooler. (my own design). Have not had the head re-torqued since the rebuild. . is that what it might need?
If it is the Head Gasket, How much would a shop charge to do this? I have never done this or messed with the injectors.
TIA,
Eric
TIA,
Eric
