2nd Gen Non-Engine/Transmission sending unit
Engine/Transmission (1994 - 1998) auto trans
2nd Gen Non-Engine/Transmission Aftermarket wheel help
How many people have had fuel tank send unit problems? What is easier pull the bed or pull the tank? mine is find until it gets to a half tank then it bounces all over the place. Has anyone using the TST kit or changeing the plate had any problems? I am thinking about changeing mine I am pulling 9000lbs and need a little more power on Hills my truck is all stock.
95 2500 2x4
i jsut upgraded my fuel sending unit with the update kit available on this site (do a search, cost=$3) i did both i started to lift the bed and i couldnt get it high enough to realy work under the truck. so i dropped the tank which in my eyes is easier, jsut make sure that it is close to empty. i also added a #5 plate which made a he11 of a difference in the power, if you have an auto beware stock it wont hold much power, hope this helps
I think just about everyone has had the fuel sending unit fail (usually around 50k miles. There are tons of old threads on this common problem.
