Engine/Transmission (1998.5 - 2002) Serpentine belt # with no A/C?
Engine/Transmission (1998.5 - 2002) Hard starting update
2nd Gen Non-Engine/Transmission Power windows
Anybody know the serpentine belt # for a 2001 with no A/C. I am looking for a spare for just in case the A/C compressor dies... ... ... ... .
Thanks
Assuming that your 2001 is the same as my 94 and 98. 5 then the A/C bypass belt is a Gates K080655. It is tight going by the A/C clutch, but it will work. I have done it before. The belt used with A/C is a Gates K080811. Get a bypass belt in the truck with you 'cause the A/C clutch can die and lock up with very little warning.
Mike
will this work, put the non ac belt on a truck with ac to bypass a bad compressor? My compressor is locked up as of last night and I need to drive it, I was planning on trying this tonight.
