2nd Gen Non-Engine/Transmission Service Body
Anyone know if a service body from a '95 Chevy or other similar years will fit on my '01 without too much work? I found a truck for $1200 with an 8' aluminum service body on it, but haven't been able to get any dimensions for it.
Use Google, call a body manufacturer. Any of them should be able to tell you frame dimension differences between the '95 Chevy and your truck.
A traditional standard wheelbase chassis cab has a 34” frame width, and a 60” cab-to-axle. A regular 8' pickup with the bed removed has a wider frame width (varies between make and year, I think your Dodge has a 37. 6” frame width, and some of the Chevrolet pickup frames even taper in width), and 8' bed pickups have a 57” cab-to-axle dimension.
You will have to check all the frame dimensions and also how the service body is mounted to see if it will fit.
Home | Dodge Body Builder's Guide
GM UPFITTER - Publications
Most service bodies are made to fit 34" frames. Every time I have installed one, I have had to make brackets to fit the dodge. On one I had to cut into the lower tool box to be able to fit around the front spring mount.
