Sorry for long, but need some help here.
I sent sticks to Don. They reported that 2 were good the other 4 wouldn't chatter. I had them bump from 5's to 5.5's. Got them back and installed. No more stumbling. However, a new issue arose When I put it into D from P the idle changed = increased abruptly then settled in as usual, odd I thought? Then immediately upon 1st run, after a few WOT pulls (1 with Edge at 1/1 and then at 5/5) to show a buddy of mine how its running, and after driving a minute or two I stopped to back up (I always put in N before going from D to R or R to D, and typically when at a traffic light I place in N) put in N then into R and it stalled=WTF!!! This "NEVER EVER, EVER" happened before, started right up but wondering WTF changed??? Only thing that changed was the injectors...
So I figured it would clear up, nope, still same thing. Really odd doesn't mater if the engine is cold or at full operating temps (including trans temp) when I put in gear the idle abruptly increases for a split second and/or stalls. It runs awesome when your running, really confused...
So I sent April (@ Don's) an email explaining the situation offering to send a video with sound if that would help.
*After talking with Don she replied, "There is a 99% chance there is an issue with the injector seating with a connector tube. You should be able to back everything off and re-install to fix the problem". BTW no response regarding my offer to send video with sound...
*I replied, "Sounds logical. So loosen injector top hold downs (strongbacks under valve cover) then loosen injector supply line nuts, re-tighten supply line nuts and then tighten injector hold downs. Will give that a shot and let you know".
*She replied, "Yes sir! And check the valve lash as well".
* I replied, "I acquired new o-rings at the local Cummins shop and installed them yesterday. Upon inspection of the supply tubes the #4 o-ring had a slight tear (I sent a picture). From memory, the #4 injector was the worst looking of the set I sent. No more stalling, yeah! I also checked the valve lash (cold) which, since the first time (@ 100k miles, presently 255k) I've always set @ IN 0.010" & EX 0.020", only 3 rockers were slightly off. There's still a blip in idle that never occurred before when going from neutral to to D or R, but no more stalling. I'm thinking once the ol' 24 valve gets used to having a new tune it'll settle in."
After driving it around for the day it stalled on me 2 or 3 times, so I sent another email-> "Looks like I spoke to soon. It stalled 2 times today going from D to R. Any ideas? I could send a video/sound file if that might help?"
*She replied, "In the past we have seen a worn pump cause this issue and if the torque converter is real tight, that can do it as well. I am not saying that is what it is but it has been a problem for guys in the past."
*I replied, "I can see a bad pump causing something like that. Just weird that all of the sudden with tuned up injectors it started. It's almost like it idles too low. VP isn't original one I replaced with new Bosch some years back and have a Walbro pusher on the frame, 2 filters big line kit, gauge is steadily from idle up to wide open throttle regardless of setting on Edge Comp. I'll check all electrical connections and throw another ground from engine to body and then to frame on and see what happens".
So that was yesterday, 9/16/2020, and I haven't driven it since and haven't done anything yet. Thankfully I have a 2nd car to drive.
I'm not saying there's anything wrong with the renewed sticks and I seriously doubt that all of the sudden the VP decided to act out, but WTF could be going on? I cleaned the tubes (removing and reinstalling "one at a time" to be sure same tubes whet back in same holes) before installing tubes with new o-rings I put fresh oil on them. When I say "cleaned" I mean, I wiped them off with a lint free cloth, blew thru them, wiped dry, made sure o-ring groove was clean and dry, then rolled o-rings on, oiled them and they pushed right back in the hole stopped at o-ring, then with light finger pressure a slight "click" and they were seated into the injector. I tightened high psi line nuts, checked torque on the injector hold downs/strongbacks and then checked valve lash. 3 rockers had lash that allowed the feeler gauge to slide out too easily (for me) so I set them as I always did (0.010" Intake & 0.020" Exhaust), no change, same thing, DRIVING ME NUTS!!!!
Any experience with this situation or ideas on where to go next? BTW this situation occurs regardless of Edge settings and/or if it is off all together or on...
HELP, PLEASE!?!?!???
