The "Perform Service" message will display on the EVIC each time you turn the ignition switch to the ON/RUN
position to indicate a emission maintenance is required. To reset the "Perform Service" indicator system (after per-
forming the scheduled maintenance) refer to the following procedure:
• 1. Turn the ignition switch to the ON position (Do not start engine).
• 2. Press and release the brake pedal two times.
• 3. Fully depress the accelerator pedal slowly two times within 10 seconds.
• 4. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illumination when you start the vehicle, the "P
