I have the same bearings but by a mistake I found that you can repack them. I had put a puller on the disc trying to remove it from the axle. The bearing assembly pulled apart ( not the rollers). The inside and out side bearings are held together by a press fit sleeve. I cleaned the inside and out side bearing and repacked by hand. I have my own shop press and I just pressed the shells back together. If you do this , don't press the bearing halves all the way down. It will get to tight. Leave a small amount of play and use the axle nut to preload the bearing. It worked great for me and I did both sides. 300 miles so far so good!Originally posted by Simon
I was going to service my front and rear axles on my 96 4X4, change oil and pack the front bearings. I was told you can't pack the front bearings. Is this true?
I don't know if you were referring your question to me or Simon but the grease in my bearings at 85k was black. That might be the original color or might not. There was nothing wrong with the bearings. After I cleaned them off they looked very good.Originally posted by TPlasek
How did the old grease with 100k miles on it look. I have a 2000 with 105k, and I have been thinking about how much grease costs vs how much a bearing assembly costs...
