I'm interpreting your problem as being the brake booster leaking down. I have noticed that after I shut down, if I hold pressure on the brake pedal for a while it will slowly settle to the bottom and not recover. I have also thought I heard a very faint hiss near the booster after shutdown as well. The brakes seem to behave normally when running/driving etc though. What do you guys think????
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar,Dual Shock Front Stabilizer,BD Injectors,31/2" Mandrel bent exhaust,16cm 'Hot End',Modest Pump Tweaks/Timed,K&N Air,Isspro Pyro,Tach,transmission Temp,Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots. 101,300 Kms (63,000 mi's).
