I am trying to get the pump timing reset on my early 98 12V. Somebody had the head off before I got this one and apparently didn't get the pump timing correct or else it slipped after they got it back together. Anyway, it seems to be retarded now and I have called several diesel shops as well as Dixie Diesel, a local Mid-Range Cummins Distributor and all of them tell me that they set the timing by locking the pin in the timing gear and then locking the pin in the pump. They tell me that this will set the pump to the factory specs. My question is if I want to advance the timing accurately above the stock specs to say 15. 5 or so and using the specs given for the plunger lift , where does anybody get a shop to use the dial indicator-plunger lift method. I'm located in Middle Tennessee and need a shop that can and will do this adjustment accurately.
